Hit the Red shortcut button. Then choose to select another tuner.That kangaroo is telling you that your Hopper channel is joined on another TV in your system. There is an option to disable it in Menu. I can't remember exactly where it is but someone will pop in and tell you exactly where.
That option is given with the Red shortcut button. Then choose the other (if) available tuner.That's one way but you tie up two tuners that way. If you disable the kangaroo sign you only use one tuner and share the channel.
I have looked for at option to disable, but have never been able to find. If anyone can give specifics, that would be great. I already have all of the notifications disabled, but the kangaroo still appears
Is it the little kangaroo that appears when auto hop is skipping the commercials?
Limited time offer
