I was talking about that a few days ago. Hopefully when I get U213 it will fix mine.And my first noticed glitch.
Exiting an app, causes a total black screen with audio only.
Only fix reboot, or enter and exit netflix.
Let's try again Dish.
Samsung Galaxy S6 Active
That's interesting that you had that with U210.I was talking about that a few days ago. Hopefully when I get U213 it will fix mine.![]()
The H2s also have that OTA issue?Still no fix for the inability to add OTA channels after a channel scan.
I've seen a few other people mention it. Normally I wouldn't care, but my market recently added a new subchannel and I can't watch it through my H2.The H2s also have that OTA issue?
I can't get OTA, so I've never checked.I've seen a few other people mention it. Normally I wouldn't care, but my market recently added a new subchannel and I can't watch it through my H2.
Yeah, you can, but there's a convoluted process that's not intuitive that works. I thought they fixed it in this release, at least part of it. Previously, I was unable to edit the channel list, specifically, to remove channels, but can do so now.Still no fix for the inability to add OTA channels after a channel scan.
What I've just tried multiple times is to REMOVE ALL of the scanned OTA channels and remove them. It goes through the motions but they remain. The intuitive process is, correct me if I'm wrong
1) Choose "Select All"*
2) Choose "Delete"
3) Choose "Save"
4) Confirm (Yes) that you want to save these changes
* Before you do this, you have to de-select and then re-select at least one channel first before the "Delete" button is pick-able.
Doing this, the channels all remain.
Yep both my Hopper PTA had to be shut back off.Don't know what has been fixed yet. Hopefully timer management is more reliable.
Did notice that sorting by episode is still backward (newest to oldest). Also, this update enabled Prime Time Anytime so I had to go in a turn it off again.
Limited time offer
