The Official SatelliteGuys TV Repack Topic | Page 2 | SatelliteGuys.US
It means they've sold the spectrum under the WPWR license. They can and almost certainly will channel share with another broadcaster.
- Trip
And by channel share, do you mean they will become a subchannel on a channel we already have?
These are the 12 stations that are going off-air completely (no channel sharing):
WAGT Augusta GA
WPBO Charleston-Huntington WV
WAOH-CD Cleveland-Akron OH
KATA-CD Dallas-Ft Worth TX
WFXI Greenville-New Bern-Washington NC
WBKI Louisville KY
WWJS-CD Louisville KY
WDLP-CD Miami-Ft Lauderdale FLWN
I believe that WNVC and WNVT are also going away completely.
Wont the three full power stations being moved to channel 26,27 and 28 cause problems?
New
Ch
Curr
Ch
Callsign City of License Operator Ph
12 12 WICU-TV ERIE, PA Lilly Broadcasting
21 16 WSEE-TV ERIE, PA Lilly Broadcasting 6
26 22 WFXP ERIE, PA Nexstar Broadcasting 4
27 50 WQLN ERIE, PA Public Broadcasting of Northwest Pennsylvania 6
28 24 WJET-TV ERIE, PA Nexstar Broadcasting 4
No. In digital, stations which are close together geographically and have similar antenna patterns/heights/powers can be on adjacent channels. Even today, Los Angeles has 31-32-33-34-35-36, for example.
- Trip
Reactions: Albiondon
FWIW WDCW (CW in the DC market has apparently confirmed they will channel share but has not made it clear who their partner would be. This according to dcrtv.com.
WAGT Augusta GA
WBKI Louisville KY
WNYJ New York NY
WMEI Puerto Rico
WSJU Puerto Rico
KSPR Springfield MO
More than that however. In Tampa WUSF sold and isn't going to remain.
The problem with sharing will be likely the loss of some sub channels - or degradation of signal. And of course as we know harder to get VHF channels.
Do we know this, or is this just the lament of those who drank the HD TV antenna Kool-aide?
In looking at the LA market, they've certainly packed the DTV stations up at the top end (22-36 are all assigned except for 26 -- still trying to get my head around 27 being assigned to two stations but I guess one faces West and the other East). Makes me wonder what the broadcaster's plan for adding a new modulation scheme might be or if they're going to jockey things around once the second window opens.
I have a VHF high station in my DMA, Wjrt-12. It's one of my easiest to get. High signal, and no preamp needed. Unlike my UHF stations.
I do have an outside separate VHF antenna. An older Antenna Craft Y10-7-13. It's 10ft long. They were about $26.00 4 years ago, before Antenna Craft went down the tubes with Radio Shacks bankruptcy, so you can't get them anymore. However, a good replacement is this one: http://www.mcmelectronics.com/product/30-2476 and only $35.
MCM Electronics is a good source of cheap antennas that work well. Solid Signal sells the same Stellar Labs antennas under a different name, just at a higher price than MCM.
Reactions: larrykenney
It isn't even up for debate I thought. :) I 100% know this from both the change to digital in Ct and Tampa. I can't even get channel 8 in Ct anymore. (Actual Channel 10) but get channel 59 from the same tower. (Actual channel 59) WTSP in Tampa had no problem when analog reaching it's market but after going digital they had to move to where most of the other towers are and get granted a power increase.
http://www.tvnewscheck.com/article/35850/digital-vhf-needs-a-power-boost
http://jackatcet.blogspot.com/2013/10/the-problem-is-not-in-your-set.html
Notice that none of the Lafayette Louisiana stations made any changes yet. KADN Fox 15 made some changes so I assume KLAF-LD 46 the new NBC channel is branded as NBC15.2, which it was called KLAFTV2 but with the changes I look for either the 46 get sold or shutdown completely, I'll edit when I get more answere
WAGT Augusta GA
WBKI Louisville KY
WNYJ New York NY
WMEI Puerto Rico
WSJU Puerto Rico
KSPR Springfield MO
Add MNTV channel 18 out of Lansing Michigan too.
High VHF is very hit or miss, and it seems to vary by station and, of course, by receive antenna. Low-VHF is pretty universally terrible.
- Trip
I agree it's very susceptible to high-powered FM radio stations, and electrical interference. I myself had to permanently unplug a Harbor Freight battery charger in my garage (you could pick it up 300 ft away, on an AM car radio!). I also had to replace a noisy Dell laptop power supply I had in my living room. The FM radio issue can be cured with an FM trap filter, and the electrical interference can be methodically eliminated.
Reactions: towerdude
Note that KLAF is not Class A, and thus, not auction eligible.
Reactions: Tampa8
- Trip
Agree. VHF-High considered pretty great real estate (the broadcasters refused to give up VHF-High in the digital transition), and VHF-Low is pretty bad.
Phoenix Suns go OTA
KWPL-LD rf ch. 30 remapping ch. 45.1 is now on the air.
