We will be moving shortly and without DISH for a few months. In the meantime will my deactivated Hopper 3 play recordings from the EHD?
When you say deactivated, are putting your account on hold, or are you cancelling?
3 mos, I believe. Best to call and find out. If you cancel the account, then start another, all your recordings on the EHD will not be watchable. EHD is tie to account #, not name or address.Didn't know putting on hold is an option. Does that keep the Hopper activated? That would be perfect.
Does putting on hold have a time limit ?
You may have solved the hold problem but I think Hopper still needs to be connected to a DISH signal to continue to work playing back EHD.
Limited time offer
