Mine do not. Walked away for about 10 minutes and they were still there...this was watching live tv.C
My red line and controls disappears after a few seconds
The pause and scroll won't go away on the bottom of the screen.
To dish support, 1- definitely missing the LIVE TV button.
2- Missing the Recall option!
3-The red progress bar really needs to go or fade away. It cuts across most channel banners etc..
Well that's no good, sjhart. I am sorry to hear that you're having an issue accessing your live channels through your Hopper. I would be happy to help get it working like it should again. This error normally indicates that there is an issue with the information between your Hopper 3 and DISH Anywhere. I would like the check a few things that are normally the culprit for this issue to see if we can get it working like it should. Sometimes the Hopper will be detecting a much lower speed than the rest of your home. To rule out that this might be the case, can you perform a speed test at the Hopper please? You can accomplish this by pressing the Home button 3 times (With 40.0 remote, the Menu Button twice instead) > Status > Send Status > Test Connections. Ideally we're looking for anything over 800 kbps. - Caleb SMine shows my hopper 3 is connected, but it won't let me watch any channels besides streaming. I'm getting Error Number 2009. This is from a Mac with Safari with the latest software (also tried Chrome with the same result). Not sure what is happening...
Same with mine, on a PC with ChromeMine shows my hopper 3 is connected, but it won't let me watch any channels besides streaming. I'm getting Error Number 2009. This is from a Mac with Safari with the latest software (also tried Chrome with the same result). Not sure what is happening...
Mine too, same thing, d/l'ing at 135 Mb/s and my house is totally connected by many devices all working fineDid the test and everything is green and Downloading at 304.764 Mbps.... Also, my iPad running wireless on the same network works fine. My Mac is on a wired Ethernet connection. Thanks.
why can I use Edge on new PC version???? I tried Firefox and could not use that either....
How the mighty have fallen.Firefox, Edge and Internet Explorer are no longer compatible browsers
More like Dish needs to play catch-up.How the mighty have fallen.
Sounds they will, in timeMore like Dish needs to play catch-up.
I was talking about the browsers.More like Dish needs to play catch-up.
Can no longer log in to Dish Anywhere or the Dish community forum, keep getting this message "Your Online ID/Password combination has expired.
I'm using Chrome, still won't accept correct log in even though it did 2 days ago - they've changed something.Huh. Same here with FF. Maybe Chrome?
Limited time offer
