Which Set Top Tuner Now??? | SatelliteGuys.US
Benny-W5TYZ
40
10
Orange, Texas
I just returned my 3rd HD Silicone Dust Dual tuner. First unit had a bad power plug receptacle on the power port. Second would not pick up the same channels I was receiving with my Visio TV scanner program. the third one would scan 45 channels, but would only show about 22-25. All the missed channels showed up on TV as "Video type not supported" Next time I would scan it would pick up the "Lost" channels and lose some others. I have 3 antennas up 30 feet because my channels are east and west of me (Zip 77632). I am not using a signal pre-amp. Silicone Dust accused me of running an amp and just overloading their system. I would still like to have a separate tuner that I could use for tuning. The HD homerun had a great program for antenna tuning. I also like the fact that I could run two TV'S off of the unit. What else is out there, that is reasonable and has good reviews? Right now without a set-top tuner I am receiving 45 channels, which I never received with the Homerun Duo tuner. Does anyone have any suggestions? My received channels are from 9 to 62 miles.
Thanks,
Benny - W5TYZ
Reactions: spongella
Hi Mike...
Thanks for your response...I am really not interested in a DVR option, however, if it comes with it OK...We would prolly not ever use that function. What kind of track record does this unit have..
Benny - W5TYZ
Pretty good actually. I presently use a Tivo Roamio, BUT, if I ever have to replace it, it'll be with one of these.
I have 2 tablo players and a new homerun tuner for the for the new Nextgen signal and consider the homerun a waste of money and wish I would never have seen it. The reason I have 2 tablo players is I have 1 antenna aimed north for erie so named that one erie. The other one I have aimed south for pittsburg for and named it pittsburg. Once you have them registered to your wifi you don,t need the computer to scan channels or anything else. I have roku + sticks, amazon fire sticks and a Nvidia player that can control any of the tablos operations. With the homerun you have to do channel scans with the PC which is a pain in the butt for me. Also I don,t even want to get and make any investment in the harddrive system you have to have to connect to your computer to record with. With tablo each player needs it,s own plug and play xternal hard drive to run it. which is simplier for me.
Reactions: primestar31
I've looked at them and have about decided on the Tablo Dou with the built in memory. Just a few bucks more, in case I ever want to record, I won't have to go looking for the memory stick...
Thanks for the input..
Benny
Thata kinda like I am. My main stations are East toward New Orleans, and West toward Houston. I have two antennas also up at 30 ', and a third one up at 35' UHF only, Long Yagi, and I'm able to get 45 channels real good out of the 3.
Thanks again for the input...
Benny
You must live around Sandy Lake PA...My home town...
Benny - W5TYZ
I live between sheakleyville and Hadley, West of route 19 about a mile as the crow flys. Actually about 9 miles east of sady lake. You need a ext hard drive to run the tablo . They have a website and forum that preety well explains everything you need to know and recomended hard drives. While editing my post I see a recomendation about the Mediasonic which is similar to the channel master dvr I use to scan channels when I want to peak the antenna position that I have on a rotor.
I have 3 antennas up 30 feet because my channels are east and west of me (Zip 77632)......I would like to have a separate tuner that I could use for tuning.
Hello, Benny; welcome to the forum.
Your rabbitears.info signal report:
RabbitEars.Info
I suggest you try the Mediasonic HW-150. It has a tuner that is at least as sensitive as my SONY TV and is able to add a channel after scan.
It also has a signal quality scale (SNR/MER) that shows the Digital Cliff (SNR 15 dB) at 39-40% which is helpful with antenna experiments.
There are a couple of good Trout Streams, close to you at Guy's Mills. I grew up there in Sandy Lake then my family moved to Texas. I still own a Camp close to Tionesta.
Thanks for the info.
Benny - W5TYZ
RabbitEars.Info
HI Rabbit...That tuner looks interesting, more what I'm looking for. Like I said as far as a DVR, I most likely would never get used. I had one with my Dish subscription and in 4 years it never got used. I'll look this one over and see what it will do...
Thanks again,
Benny - W5TYZ
That tuner looks interesting, more what I'm looking for. Like I said as far as a DVR, I most likely would never get used.....
The DVR feature on the inexpensive converter boxes isn't that great, but the tuner is sensitive and the 39-40% Signal Quality point is similar to the 50% Signal Quality point on the SiliconDust HDHR GUI:
and you don't need a computer to use the Mediasonic HW-150.
Benny - W5TYZ
RabbitEars.Info
HI Rabbit....
I received my new Mediasonic 150 STB from Amazon about an hour ago...Sunday delivery. That thing is smooth as glass. I already picked up 4 more channels that I was not able to get with my Smart TVwhich is a total of 49 now with several dup's and 3 times as many as I scanned with my HD Silicon Dust STB, at 1/3rd the price and it has a built-in DVR. Thanks for putting me on to this. It took a while to figure out that when the pilot light is on the unit is off. I finally figured I'd just wait till tomorrow to fool with it and I thought I was shutting it off and here it came mon. I could buy 3 of these 150's for what I paid for that HD Homerun. I did get a full refund though...
Benny - W5TYZ
HI Rabbit....
Benny - W5TYZ
I just found out that all channels are showing up as B&W, no color at all. What happened. This is on my just installed Mediasonic -150. What did I not get connected?
Benny - W5TYZ
Benny - W5TYZ
Try replacing the HDMI cable. Maybe even just reseating it will fix that issue. I'd pull the power plug first, reseat the HDMI cable both on the dvr, and on the tv side, and plug it back into it's power and see what happens.
Grio, now on KTVS-LD in Albuquerque
THIS TV subchannel
