How do you setup a VPN to a different US city and not a completely different country? | Page 2 | SatelliteGuys.US
Can anyone recommend a website of which I can use my VPN and get different locals while using just a free trial? I just want to experiment and I don't need it forever. I tried YouTube TV and canceled right away since it wouldn't work, and my other Google email won't let me use a free trial anymore due to me trying it a few years back. Locast doesn't seem to work either. I just want to experiment and I don't even need cloud DVR service.
Do you have your VPN connected to a server in a Locast served city?
I see ExpressVPN advertises that it works with Locast, but I don't want to spend that much.
I can attest that NordVPN also works with Locast. I don't know if there are any fake GPS apps for iPhones, but the one I use on my Android phone also works well with Locast and cuts out the extra data traffic used by the VPN servers.
Well I did everything I could to try to get the Locast app (as well as try multiple browsers) on my iPhone to work with my VPN, but somehow I don't think it's compatible. Maybe it works on Android like NYDutch said, but I don't think it works on iPhone. Maybe it works on one newer than iPhone XS (even though it's pretty new itself). But I'm satisfied that it at least works on my Mac.
Can't say for sure, but Locast proabaly uses iPhone's GPS, not your IP, to geo-locate you for their service. You'd need a jailbroken iPhone to override iPhone's GPS. On Android, I believe it's more simple. I don't think you need root access on Android, but it's been awhile since I've tried it.
  • Sad
Reactions: TheKrell
Yep, no root access needed for Android phones, and according this website, not for iPhones either. I can't vouch for the accuracy of the info given though.
I looked up jailbreaking iPhones and it says it opens up the possibility for malware. I think I'm good with just watching other markets on my computer. I don't want another phone or anything, and a lot of trying to do all this sounds a little complicated. I'm perfectly happy watching other markets on my Mac. I could always find a internet TV provider in the future that will just use an IP address, or whatever will happen in the future. Watching them at home is the main thing I want to do.
Reactions: comfortably_numb
You can get a fire stick or fire tv..there are many vpn's that work on that
And you could cast the Mac signal to your TV of course, if that would be better for viewing.
Domino's launches autonomous pizza delivery with self-driving robot car
Be careful with your watch in Las Vegas
