You can find more info here: https://my.dish.com/support/receivers/androidtvcan someone please explain again the advantage of the Hopper+?
Thanks! That's what I thought, since the download occurs in the background, while I am using the receiver for other things. It acts just like any other streaming download, such as VOD, etc. That is why it confused me when HipKat said I didn't have the Android software.They do have the Android software. The method they used to download was not via satellite.
That is true but only some receivers are targeted to receive vit. If your receiver is not targeted you will receive an error message when you try to downloadTo clarify, the software pictured is available to the public. I do not have a Beta receiver. To see these versions, go to Tools > Technician Settings > Download ATV Files
In any event, the software versions I listed are publicly available (by some method) but are not listed in the "official" (sticky) new software thread for this month (which had not even been posted yet at the time I started this thread). So, I thought it would be a good idea to list them here, whatever these particular software versions actually do.While you may have the Hopper software to support the Android platform, you do not have the actual Android software as you don't have an Android device. Confused yet?![]()
Okay, that makes more sense. So, the USB drives are for Hopper 2's or 3's that are not yet targeted for the new software, to force them to take the update. Once all receivers are targeted, then the USB drives will no longer be necessary. Do I have that right?That is true but only some receivers are targeted to receive vit. If your receiver is not targeted you will receive an error message when you try to download
Well, yes and no (maybe). When I did the H324 download, all of the old "make Hopper ready for Android" software versions (that I posted in the xx21 thread) were wiped out. They disappeared from the Diagnostics screen. However, I selected the Download ATV Files button again after the main software download, and those files (that I posted in post number 2) downloaded in the background just like the old versions. They are now listed on the Diagnostics screen, under Available Joey Software.If you don't have the Hopper+ and download the latest Hopper software you still will have to have the USB update when your Hopper+ is connected for it to function properly.
Not that interesting, since there was no 22 for Wally, and no 23 for anyone. (Not publicly, anyway.)Updated the Wallys today to W524. Interesting how it jumped from 21 straight to 24. Anyway, this one took a really long time, almost a half hour for some reason.
Yes sir!HipKat so is it for sure a tech visit will be required to install the Hopper Plus and new Joeys?
Because according to Dish the Android TV software will not download over Satellite, only USBThanks! That's what I thought, since the download occurs in the background, while I am using the receiver for other things. It acts just like any other streaming download, such as VOD, etc. That is why it confused me when HipKat said I didn't have the Android software.
Jim5506Okay, that makes more sense. So, the USB drives are for Hopper 2's or 3's that are not yet targeted for the new software, to force them to take the update. Once all receivers are targeted, then the USB drives will no longer be necessary. Do I have that right?
From our training, just to be clear for you guys, "The files are not available over the satellite. As stated in the update process, you can download the Android software over the internet for Hopper+ Upgrades, not for New Connects. This may change in the future but currently, the Hopper is not able to do this for New Connects, so USB is the only option."According to Hipkat the Android software will not download from the Satellite. But Pattykay claims to have downloaded the Android software. I am wondering if the download took place over his internet connection rather than the satellite. It could be that the Dish installers have the Android software via a USB drive since they don't know how fast a customers internet is. I am just guessing.
Joey 4's are Android? If so, what do they need a Hopper + for?I don't think the Joey4's will work without a Hopper+ because they are Android and the Hopper+ is Android but the Hopper 3 is not (I could be wrong about this last bit).
You do have the latest software versions, but you don't have the android software which can only be downloaded off of one of our USB drives that we carry. Dish has reiterated several times this week that the android software cannot be downloaded over satellite.
I'm afraid you're probably going to have to wait until they start releasing these to existing customers next month unless something changes before then
Just to be clear, brittanygarden is Dish Technical Operations and does know her stuff. If she says pattykay has the andriod software by doing what she did then I have to believe that is correct. When I go to Technician Settings on my Hopper 3 (H324) I see a tile to download ATV software. So, your initial training may be outdated at this point.From our training, just to be clear for you guys, "The files are not available over the satellite. As stated in the update process, you can download the Android software over the internet for Hopper+ Upgrades, not for New Connects. This may change in the future but currently, the Hopper is not able to do this for New Connects, so USB is the only option."
Revisiting this, brittany was clear that the software did not come from satellite so that means that it came from the internet. So, if you don't have internet hooked up to your receiver you would need that USB to download the software. Of course if you don't have internet there is no need for the software because Android is dependent on it.Just to be clear, brittanygarden is Dish Technical Operations and does know her stuff. If she says pattykay has the andriod software by doing what she did then I have to believe that is correct. When I go to Technician Settings on my Hopper 3 (H324) I see a tile to download ATV software. So, your initial training may be outdated at this point.
Limited time offer
