Sous Vide | Page 9 | SatelliteGuys.US
Sous Vide
2.5 lb Arm Roast
Salt the only seasoning
Vacuum sealed
Cooked at 131.5 F for 26 hours
Cut corner of bag and drained (saved)
Put in fridge for 2 hours
Pulled, seared in disc at pretty high heat in bacon grease
Put in air fryer pre-heated to 450 F for a minute and thirty seconds
Pretty tender, next time will try 28 hours and less salt.
Tried a slice and put rest in fridge to run thru meat slicer in morning...
I sous vide two Kansas City strip steaks for my birthday this weekend and had a oopsie in that one of the bags had leaked! The steaks were finished on the grill and were a little drier than I expected, so whether this was caused by the containment breach I couldn't say since only one bag leaked and both steaks were meh.
Cleaning the cooler I use for the bath tub was easy enough, but other than running the Anova with soapy water and a clear hot water rinse, any other suggestions for making sure there won't be any beef contamination on the inside of the immersion heater?
Quick and Easy
Snacks...
