IIRC the Dish 1000.2 is for western arc, the 1000.4 is for eastern arc. Western arc is 110/119/129 Eastern Arc is 61.5/72/77 The separation of the satellites is not the same.
No one has mentioned it so I will ask, have you checked your skew setting?
The dish would be the same, the lnbs are different.
So is that just a standard DPP Twin (the 1000.2 comes with a standard DPP Twin anyway) or is it offset or wider spread somehow?Yeah, there's a 2-LNB DPP EA assembly that goes on a 1000.2.
Using your zip code....I am having problems getting a 1000.2 set up on a tripod at a camp site. I am not getting 72. Looking at the dish from behind, is 72 the left or right LNB?
So it is an offset arrangement as I suspected. That's almost certainly going to create some aiming parameter issues since the 72.7 feed horn isn't at the center. Maybe the installation instructions contain their own aiming tables.Offset. Let me see if I can find a ref... Google led me back here to a thread that discussed this LNB, but it was a broken link.Best I can do is Amazon: Amazon product ASIN B00946HPUO
Note that it has 3 outputs, but no input for a wing dish.
Limited time offer
