H hotshot12345 Well-Known SatelliteGuys Member Original poster Aug 16, 2011 30 0 WA, USA Sep 10, 2011 #1 So looks like I would be paying the same price for either dish. Should I get the 39" then? Thanks guys.
S SatPhreak SatelliteGuys Pro Apr 19, 2007 944 143 Thunder Bay, ON Sep 10, 2011 #2 When it comes to dishes, the bigger the better. Always. Especially if they are priced the same.
Anole SatelliteGuys Master Sep 22, 2005 11,819 14 L.A., Calif. Sep 10, 2011 #3 there's no simple answer, nor a simple question What are the two dishes? What are you trying to receive? In the US, shipping a 39" dish almost always costs more. Are you planning on putting the dish on a wimpy little motor? If all things are equal, then of course go for the larger dish.
Tron SatelliteGuys Master May 6, 2005 6,599 35 Metro New Orleans, LA Sep 10, 2011 #4 As Anole suggested, check the shipping cost. On larger dishes, this can easily equal or exceed the cost of the dish itself.
