4:2:2 / DVB S2 Questions | Page 3 | SatelliteGuys.US
The ONLY standalone receiver that will do 4:2:2 is the 700.00 Quali-TV. Iceberg has one.
:D
Quali-TV appears to be a dealer. He's selling the Pace model DS-810XE receiver. Is this the receiver that you are referencing?
The receiver specs don't mention anything about 4:2:2 video. Is 4:2:2 included as part of another specification such as H.264 ?
Edit: I found a google link for a Quali QS1080IRCI receiver. Is this the one?
It was not listed as a spec but will receive 4:2:2 HD and SD, it was a bonus when people started using it and found out it did do it. The only problem is that there is a green line on the bottom of the screen if I recall. No H.264 though and no S2 and not sure of the DS-810XE model, just the original one.
The Quali-TV site is difficult to navigate. There are no satellite receivers listed under the Products tab, but the search function will find them if you know what you are looking for.
I found a google link for a Quali QS1080IRCI receiver. Is the one?
That's the one, kinda. There are 2 versions, one has Multiple CAMs, the Regular one just has Irdedo.
The QS1080ir in not made any longer.
The "Green Line" is only on HD 4:2:2 feeds, can be "hidden" if the TV allows you to adjust the Pic's position. Most HD TV's do.
$700 is for a new unit, you can get a used or referb for almost half.
There is one For Sale in the Sat Guys Classified section. :) :) :)
http://www.satelliteguys.us/satelliteguys-classifieds/155034-sale-qualitv-qs1080ir.html
I checked, and 4:2:2 Chroma Sub-sampling is supported under the H.264 Video compression specification.
I would reasonably expect a receiver that is H.264 compliant to be able to decode 4:2:2 Video.
But if the use of 4:2:2 is used outside of H.264, like the NBC feeds do, an H.264 receiver can not decode it.
What compression spec does NBC use? I thought that they recently switched to DVB-S2. Isn't that MPEG-4 based?
H.264 chip sets are usually backward compatible with earlier standards. If the capability to process 4:2:2 is built in, it would not make any sense not to use it - unless it's a marketing strategy.
The Quali-TV receiver uses the Broadcom BCM7035 chip set. The chip handles MPEG-2, but not MPEG-4.
correct
The Q can handle 4:2:0 Sd, 4:2:2 SD, 4:2:0 HD & 4:2:2 HD all MPEG2
The Coolsat 8000 can handle MPEG4 but not 4:2:2
The 4:2:2 are MPEG2 DVB, but those are only Specs, not limits. There is no rule that they Have to follow.
I don't believe 4:2:2 is in the MPEG2 or DVB Standards.
Correct
The Diamond 9000HD uses an STi7100 chip set, it's MPEG2 and MPEG4 / H.264 "compliant", it can not do 4:2:2.
correct
They are not advertising that they are H.264 compliant or DVB-S2 compliant, so this is reasonable.
Some manufacturers are advertising DVB-S2 and H.264 compliance. They may be lying, but they're still advertising.
The CS8000 IS mpeg4(h.264) compliant . That is the European standard for the HD DVB-s2 receivers, since that is what Europe HD runs on. I expect that those manufacturers claiming mpeg4 compliance are advertising the same thing. It is standard on everything I've seen that does DVB-S2 .
"Brilliant On Screen Graphic
MPEG-2 & MPEG-4 Fully DVB Compliant
MPEG-2 Video (MP@ML), MPEG-1 Audio Layer1,Layer2
LNB Controlling Logic
SCPC/MCPC Receivable from C / Ku-Band Satellites
Digital Tuner with Loop-through
HDMI, Component, RGB/HV, S-Video, Composite Video, Audio L/R
Wide Symbol Rate 1~45Mbps & Frequency Input 950 ~ 2150MHz
DiSEqC 1.2 Supported
S/PDIF AC3 Audio
User friendly OSD Menu with Full Function
256 Color Graphic User Interface
Multi-language menu
4-digit 7-segment LED Display
Variable Aspect Ratio (4.3, 16:9) with Pan Vector or Letter Box
EPG(Electronic Program Guide) for On-screen Channel Information
Teletext and Subtitle Supported (VBI & OSD)
Installation by Easy Setup Guide
Capacity for Storing Multi Channel (FTA.2500 Channels, 500 Transponders)
Favorite Channel and Parental Lock Function
RS232C Port for Upgrading System Software
Input Frequency 51~862 Mhz
Implement complet DVB-T (ETS 300 744) standard
2K and 8K transmission modes
No=Hierarchial and Hierarchial support
Optimized for both SFN and MFN enviroment"
From the manual.
H.264 compliant doesn't mean it implements all profiles. Supporting High Profile is enough for Blu-Ray to be considered H.264 without supporting High 4:2:2 Profile. So while H.264 has 4:2:2 in the standard, instead of an optional extension or whatever to MPEG2, there is no requirement to support it.
satmex 5
Old round starchoice dish
