I'm primarily interested in the SD & HD NBC feeds and the RTN S2 feeds on C band.Coolsat 8000 & 8100 do DVB-S2 out of the box
Stay away from the MaxHD, no dvb-s2.
4:2:2...black screen, audio is there but shows "no video" on screen
AC3 built in...no additional decoder needed. My 8000 works fine on AC3 and I use the RCA cables to run to the DVD recorder
unless its been PROVEN to have such a spec dont believe it....hate to be cruel but thats the truth
The captiveworks I have (CW600) CLAIMS blind scan in the specs and it doesnt work at all
The viewsat I had (the original) CLAIMS motor control...well it did have motor control. Too bad it wouldnt stop at the right spot
so if someone who tried a product says it doesnt have a spec that is listed (or claims to have) thats good enough for me![]()
vfrjim said:Unfortunately, I am not ready for a review yet, it is a buggy receiver if you ask me.
Heck, it would not find any S2 feeds with factory firmware at all and Viewsat sux at responding to problems.
ABC SD NET-14which ABC ones? G16? Those scan in just fine and work perfect on the Q...both SD & HD
G25 is a bugger for me on C-band....only have 6 foot dish![]()
I remember reading that thread, but I think it was later mentioned that a firmware update fixed a lot of the problems, so I haven't completely dismissed Viewsat as a possible receiver choice.please read my first sentence in your quote.....but since you dont want to believe me here is a post from vfrjim who had the receiver when asked about a review
maybe he can elaborate on that
The MAXHD specification advertises that it is Fully MPEG-2 & DVB-S2 Compliant.
What's the story?
The ones on G16 are 4:2:2 video. I don't remember seeing anything there. Probably because the screens were black.oof...havent tried that batch yet...I know of the ones on G16 and those are fine
Maybe they fixed it but when I got rid of it a month ago, it could not find a dvb-s2 with a seeing eyed dog... and I was not too happy with their customer service.
I am very happy with my new PC that I built, does s2 and 4.2.2 without problems
um, they only have 2 C-band muxes
G3 which is DVB
G28 which is DVB-S2 and never was "converted" to DVB-S2...it was brought live in that format
I do have a PC that I could dedicate to S2. Perhaps this is the best solution for now.
What card are you using?
What's the story?
From my knowledge the Viewcrap, oops I mean Viewhack, aww man I mean Viewsat Max does not do dvb-s2
There's 3. Your notes are missing one and it's kind of shocking, considering the 3rd one has been around 6 months or so.
Limited time offer
