44 Switch | SatelliteGuys.US
44 Switch
Spike
616
59
Suburbs of Milwaukee
I am about to purchase a Dish Pro Plus 44 switch. I already have a DP 34 switch and a DP 21. What will the addition of the 44 switch allow me to do in combination with the others?
I know the obvious answer, which is that it will allow me to hook up to four sats to my current set up, which is one receiver.
The sats I'm pointing at are 110, 119, 129, 148, and 61.5.
My receiver is not allowing 148 and 61.5 on the same switch with my current set up.
:cool:
sorry, I originally posted this in the wrong place!
What model receiver are you using? Some do not work with 61.5+148, some do.
A DP21 + DPP44 will give you five sats, with the DP21 between the receiver and the DPP44, port 2, 3 or 4 (port 1 MUST have the power inserter). Search here for "mad scientist"
a Petion to add Nbc30 weather plus
SuperDish and 105 on PanSat 2500a
