Stargazer Supporting Founder Supporting Founder Sep 7, 2003 16,567 340 Western WV Sep 18, 2003 #21 I shouldn't matter what version it is to anyone, since consumers will not be getting that version number of software.
G Guest Guest Sep 18, 2003 #22 He says could be AVNT or ALK1, but if you will give your receiver serial number he will find it precisely.
Scott Greczkowski Welcome HOME! Original poster Staff member HERE TO HELP YOU! Cutting Edge Sep 7, 2003 103,427 28,490 Newington, CT Sep 18, 2003 #23 Fat Chance.
G Guest Guest Sep 18, 2003 #25 I'm just recall - he told me a few months ago, you'd post at DBStalk a screenshot with your serial number; may we should take a look back there .
Scott Greczkowski Welcome HOME! Original poster Staff member HERE TO HELP YOU! Cutting Edge Sep 7, 2003 103,427 28,490 Newington, CT Sep 18, 2003 #26 I have a different unit since then though so it wouldnt do any good. And BTW the init id and smartcard numbers were scrambled (I cut and pasted the numbers over numbers) Sorry.
G Guest Guest Sep 18, 2003 #27 Anyway, what is you beta version ID ? He says that all what was and exist now.
ken SatelliteGuys Pro Sep 8, 2003 296 0 Sep 18, 2003 #28 Guest, Mind your own business. You are either a Dish employee or a trouble maker.
G Guest Guest Sep 18, 2003 #29 I'm just curious person, but you .... out of question ! Doesn't have selfesteem and putting down other ppl. Heh .
120inna55 Supporting Founder Supporting Founder Sep 14, 2003 1,454 31 Athens, Texas, United States Sep 19, 2003 #30 BOOT! BOOT!!!
ken SatelliteGuys Pro Sep 8, 2003 296 0 Sep 19, 2003 #31 Guest, perhaps my remarks would have changed if if you had not been hiding behind the guest tag. Why not sign up as a member ? Then I would know if I was knocking a DISH snoop or just a nut.
