721 Update | Page 2 | SatelliteGuys.US
721 Update
He says could be AVNT or ALK1, but if you will give your receiver serial number he will find it precisely.
I'm just recall - he told me a few months ago, you'd post at DBStalk a screenshot with your serial number; may we should take a look back there ;).
I have a different unit since then though so it wouldnt do any good. :)
And BTW the init id and smartcard numbers were scrambled (I cut and pasted the numbers over numbers)
Sorry.
I'm just curious person, but you .... out of question ! Doesn't have selfesteem and putting down other ppl. Heh :( .
Guest, perhaps my remarks would have changed if if you had not been hiding behind the guest tag. Why not sign up as a member ? Then I would know if I was knocking a DISH snoop or just a nut.
