A theory about some installers. | SatelliteGuys.US
VegasVoomer
672
45
Las Vegas
My install went very well. The guy was wearing a Direc tshirt and said he was a loyal DTV installer. He started bad mouthing Voom but when he left everything was working. Then a week and a half later it was very windy one night and I lost all signal. The dish was pointing almost into the ground. I went up the ladder on Friday and realigned in 5 minutes. I was shocked when I went to tighten down the bolts--they were ALL loose. And not just loose they were threaded on about 2 turns each. One was on enough to hold the dish barely in place. Even the ones holding the OTA were barely on the screws. So I'm saying to myself what are the chances this guy did this intentionally just to get a call back and another $100 or whatever they get knowing it would be a simple fix. I cant believe a real installer would forget the most important part of the install--tighten down the dish! :no
Register to hide this ad
You met the guy...I would trust your gut instinct. It could be an honest mistake, but you should still report your experience to VOOM and send Wilt and e-mail just to make sure the incident is documented. At a minimum, your installer was careless and failed to deliver a professionally installed VOOM system IMO.
dIFFERENT tOPIC! espna AND ANOTHEWR CHANNEL hd voom COMMERCIALS!
VOOM CSR live chat no longer available?
