Any rumored HD or 4.2.2 rcvrs? (non PC) | SatelliteGuys.US
JerryK
212
Hi All,
I'm a C/Ku BUD owner, and spend most of my time in that forum.
I'm wondering if any of the dvb receiver manufacturers are planning future units that support 4:2:2 and/or HD.
I'm not interested in any of the PC cards that can do some of this, so I'm kinda holding out until a Pansat/Coolsat model supports it. (or until I find out they NEVER will :( )
Many thanks,
Jerry
I have read about a Pansat 7000HD, though not sure when it will come out, also read about a Coolsat and Nuesat HD coming I guess we must wait and see..
I have the same one Mike has. I got mine from a dealer in Missouri. It is a bit pricey due to the fact it's an import, but it is well worth the money, especially when I am watching something on it that I can't get with the Satworks.
I did a search on Pansat 7000HD and found nada, where did you read about this HD receiver if I may ask?
Thx
BTW: www.pansatusa.com has nothing on this model.
Just what I have been waiting for!
:neener
Thx
Sure hope they hurry up...Been waiting for an excuse to Ebay the Viewsat Extreme (Extreme POS...that is)
That last firmware upgrade killed the RTC ...also caused a lack of stability on some birds...(No it is not the LNB since all is well on my
4DTV KU band...nothing has changed....and of course they remove the old firmwares...I have it stashed on a drive some where but It just is not worth it...Comon Pansat and or Coolsat...
HD FTA ...GIZZER awaits!!!:D
Still cannot understand why they can not fix the USALS (for thoise who need it) and put relative numbers on the Quality graph bar without having to go to the installation menus! HOW MANY WAYS TO SPELL DUMB????
Sure wish I had made it to this forum BEFORE I bought!!!! <sigh>
Hey, I am thankful that G10R is still strong....parking there more and more!:D
Jeff
I like it but...
MikeI said:
http://www.quali-tv.com/index.php?option=com_content&task=view&id=38&Itemid=46
I use the above one, but it's not with the companies you mentioned. It cost about $725 from a dealer here in the US based in Indiana
Noticed it still has a DVI connector...I would have to dig around to locate MY converter cable (TO HDMI) or use the components....everything is filling up quickly behind my setup!:D err...a little pricy to say the least...Like as in retail 4dtv prices! (or very close)...STILL MAY ARISE ONE MORNING AND GET THE URGE...HAVE TO HIDE THE CC'S!!!:D Hmmmm...just remembered...the VIEWSAT IS USING ONE SET OF COMPONENT INS ON THE HDTV!!
Did not see a mention of Blindscan and it has the euro stuff...probably should wait! (SCARTs would be a waste for me unfortunately!)
getting ready to create an auction!:)
JEFF
It doesn't have blindscan, but that takes the fun out of it anyways for me. I currently don't have that on any of my receivers.
question about input keys
captive works 6000
