obba said:I got a quick question. When you request that your box get new mapping info, will that go to all boxes on the account if you have more than one?
rudolpht said:On all, but may need factory reset on each to get all channels. This may not be an issue with the newer boxes but was with the older one. Look at Read this first thread, follow with a front panel power cycling, and then make sure red button is set to correct resolution.
Tim
Thanks. Install is on thursday, so im storming by brains for questions i might have laterSean Mota said:Yes, and the same instructions or procedures need to be done to all boxes on the same account.
Sean Mota said:pmalve,
I received your email. I have requested that your OTA mapping be changed from NYC to Philadelphia. Let's wait and see what happens. I will let you know.
xboxer said:Hi guys, If anyone has any suggestions it would be greatly appreciated.
I had my install on Tuesday, all went pretty well. I really like the service so far except the problems I am having with the OTA. I upgraded the stealth that was installed with a 80" boom from radioshack and installed it in the attic. With the stealth I was recieving WVIT (NBC) 35% signal WB 25 % and
ABC 25 %. I upgraded the new antenna and now recieve NBC 80% but I cant get a lock on anything else. I checked Zap2it and there are no channels before 100 listed. Just before giving up hope I hooked the Antenna up to my E86 and rec ratings as follows NBC 100 % WB 76% FOX 100% pax 78% I didnt lock ABC Yet. Do you there is something wrong with the mapping or what.
Thanks XBOXER
Sean Mota said:It means that your mapping is not done. Send me your address, zipcode and description of problem and will request that your mapping be added to your zipcode.
Sean,Sean Mota on 02/28/2004 said:slyscooter & n0qcu I sent both of your information.
n0qcu said:Sean,
Will this show on zap2it when corrected?
Only four (long) days to my install, I hope they get the mapping done so I will get all my current channels.
Limited time offer
