Can't delete VOD movies on my Dish Network Hopper 3 | Page 2 | SatelliteGuys.US
Same thing with either movie in the On Demand folder. Can't delete individually or together. Nothing works from previous suggestions of trying to delete these with a new downloaded movie.
Reactions: charlesrshell
Failed to reply here, see my reply in a different post
I was going to recommend Info if the Recal didn't automatically delete it.
What happens if you do press play. If it starts or gives you an expired message, can you then stop and delete it then or just delete from the expired message.
These things are like trying to find the 4 leaf clover in the entire yard of stuff to try.
NO option to play the movies.
Finding 🍀 s is my super power, found 2 yesterday!
379 just came out. Check to see if it was pushed to you and if anything changed. There has been quite enough chat about this that someone who monitors this forum in Dish Tech would have had to report it at least.
379 was installed (not sure when). I agree, quite enough chat and unless one day the option is there to delete these 2 On Demand movies, I'm done.
Same thing happened to me but I reported the issue in an older discussion topic I found when doing an Internet search about this issue.
My comments are posted in this topic.
If you have a model 40 remote and it is paired with your Hopper you can probably delete those items by pressing the blue button when you have the program title up.
I called Dish support again and they still could not resolve the issue. In fact the rep almost deleted my movies from the custom made folders. I don't think she really understood what the problem was that I called about. We may have had a more productive conversation if she eliminated all the background noise. It's hard to listen to one person in a room full of others talking at the same time.
I downloaded some MGM movies on Dish Network from VOD and saved in the DEMAND folder on my Hopper 3 when they were free. Now I can't play them or delete them. How do I get rid of them?
I believe the only way you can get rid of the vod is to reset the receiver to factory settings. That means everything will be deleted and reset just like a computer would be. I am not sure if your would need call dish to reactivate your dvr or not after doing a factory reset?
Is Dish cutting back some of its operations staff?
Conus locals still?
