Can't get satellite 110 on Dish network 500 | SatelliteGuys.US
babooola
south wales, ny 14139
HI,
I realigned my Dish Network 500 because of poor signal and loss of signal. Can't get satellite 110 now. Signal is very strong but in red and says wrong signal -satellite 119. Check switch says only one satellite. Dish is on the setting it tells me to use when I put in my zip code.
Thanks!
Sounds like you are about 10 degrees to far west in your azimuth.
You are receiving 119 on the 110 lnb, crank er back east.
Looking to upgrade to HD. Dirt help?
New 1000.2 install in place of dish 500 having issues.
