So why is it many people are not seeing Pandora or YouTube?
Not sure, Also looks like we cannot narrow it down to particular recvr models either.
have both pandora and you tube on my hr 24/200 hd dvr receiver but not on my hr 24 hd receiverwish they had it on both
Remember if your not seeing Pandora or Youtube you might need to search again for IAMANEDGECUTTER and then let it sit for up to 12 hours before it appears.
Pandora setup was very fast and easy.![]()
How do I do network issue reporting?To activate, do a Keyword search for IAMANEDGECUTTER
*** Network must be properly set up and working to use this feature ***
- On your remote, press Menu/Parental,Favs&Setup/Miscellanous Options. (you can also use the Menu+Info keys on the DVR to get to the Misc Options screen.)
- Select the Report option
- Click on Send
- Wait for it to finish
- You will receive a confirmation key in your response.
*** Please include this key in any post you make in the issues thread ***- Please note that you can only send one report per hour
- If you do not have a network connection, you will not have this option
this morning on the R22 I now have the icons, mydirectv, pandora and youtube![]()
Where do you enter IAMANEDGECUTTER at. Thanks
wildbill129 said:In the search box as though you are searching for a program. Enter the keyword, select the red button and All. You will get no results, click done.
Inputting IAMANEDGECUTTER totally did it for me. While watching football, the receiver rebooted and came back up and bingo. Pandora and Youtube icons. Took about 6 hours before it happened. Thanks for the tip!!
I lost the national realize last night /: now I have 0x4db .
Same for me as well. On my HR23 it was there immediately after download.
Limited time offer
