nothing for me HR24/500 after 3 plus hours and yes I am connected to the internet with this unit
Give it time, check in the Morning, maybe you'll really GET it for Christmas !
Why are you selecting the RED button ?
Type in "IMANEDGECUTTER," at the bottom of the screen you will see the red button and "Keyword Search for "IMANEDGECUTTER"" The red button performs the search. Same as scrolling down to the search term and pressing enter. Saves a step. It's how I always search for programs.
I downloaded the latest CE last night on my HR24-100 and I found a weird problem with the guide. When I page up or down the cursor disappears and when selecting a channel it goes to the wrong channel at times. I reset the receiver and it seems to be all right for now. It still is sluggish at times even after the reset.
So I have used Pandora twice on my HR24. It freezes after about 5 songs and can't be restarted. Even going back to live TV and back won't fix it. I have to power off the receiver to get it to work again.
What model? Works perfectly on the HR22, been listening about 50mins straight while doing a bit of gaming.
Yep, exactly what I saw.
wildbill129 said:The guide issues starting happening on my HR21 also. I did red button resets on both, the guide problem went away. That didn't work for you though?
Limited time offer
