Just can't understand why it's so difficult for broadcasters to get the formatting correct for 16:9 SD if that's the format the broadcaster chooses ....Getting 16x9 commercials but programming that is 16x9 is actually picture framed in the 4x3 area on KTUL 8.2 in Tulsa
If the scan is 16:9 and the active format is somewhere below this at usually 4:3, you use pillar-box with matte bars on the sides. If the scan and the active format are both 16:9, then the image is shown full screen. If the active format is greater than 16:9 like say a 2.37:1 aspect ratio presentation, you letter-box with matte bars on the top and bottom.
What's with all these wierd formatting combinations of a 16:9 active format anamorphically squeezed into a 4:3 scan. Or as in your case, a 16:9 active format letter-boxed into 4:3 which is in turn pillar-boxed into a 16:9 scan?
Sent from my SGH-M819N using Tapatalk
