I went through a local company to get DIsh installed. I asked about the HD channels and was told the satellite would be $2500. Does anybody know what satellite I need?. Also what receiver?.
gbjbany said:did you see thsi thread. 129 is the satelitte that has some of the HD channels on it
gigapower said:Wait until Wednesday, call Dish and ask for the DishHD service and the $299 ViP622
gbjbany said:no the numbers are the satelite locations. So 129 is at 129 degrees.
gbjbany said:It will need LNB's to see 3 satellites at 3 locations 110 degrees, 119 degrees and 129 degrees if you want some of the new HD channels.
gpflepsen said:If they are wanting $2500 for this install, STOP the transaction. You should be set up for the cost mentioned above. Who is quoting you $2500? They are crooks.
masterdeals said:What no one pointed out is he is in Alaska. Normal dishes won't work - they need big ones. I would suggest checking with other local (if there are any up there) installers/suppliers for any more reasonable options is you really want the HD on 129. Some of the HD is on 110, which probally was the dish you paid $600 for.
goaliebob99 said:he cant get 129 in alaska (its tooo low powered) He can try for 61.5 if hes not below the horizon on it..but good luck
Limited time offer
