Does the 21.0 Remote automatically come now with a new 722 or 722K Receiver - OR - do you have to order them separately?
Does the 21.0 Remote automatically come now with a new 722 or 722K Receiver - OR - do you have to order them separately?![]()
I got them with my 722k too. You don't get them with the 722.I got a 21.0 ( UHF) and 20.0 (IR) with my 722k.
None of those buttons work for me.Got them with the 222k as well. Don't like where the pip buttons are, anyone tried to program the colored buttons to perform this task?
perfect, thanks! Gonna order one, is there anything I should know to get it working when it arrives? I cant call Dish cause they claim its not compatible. Im gonna use it on my 612, I have another 612 and 622 but those wont get remote upgrades just the 1 612yes,it work:up
kevkwas,
Granted it would be easier to transfer a complete set of codes from the device data base into the remote during setup, I think as long as you have another remote to teach from (that would be your original VisionQuest remote), the worst that can happen is that you'll have to train each code individually. Since you're only likely to need power on/off, volume and mute that's not a lot to have to transfer.
What you might want to do is read the PDF on the first page (first post) of this thread to see if performing a manual programming of the remote is too confusing for you. Nothing bad intended, just that some very smart people have problems with gadgets.
I do have the Visionquest remote, and yes all I want is the TV on/off and volume. I did read the manual, but it doesn't show VisionQuest TV's, I was wondering if it would learn it if it is not listed in the manual.
Will this remote learn any remote is my question I guess.
Thanks again.![]()
YES it will. It'll learn ANY IR device. If your Bell receiver is in fact the same as the 722 you'll be fine. I use 21.0 remotes with both a 622 and 722 (NOT K) and they work great. You'll be able to say good-bye to the "two remote shuffle", LOL.
Ed
As stated elsewhere in this thread, just remember to program ALL of the commands you want for your TV at the same time.
Limited time offer
