Dish Specs, Trust But Verify! | Page 2 | SatelliteGuys.US
Bill;
I'm running into the same problem that you did with the Tek 10' dish if you've been reading my thread. With the scalar at 48" I have the lnb as far forward in the holder as I can to max signal levels but I can only get the strongest transponders so I know the LNB wants to go quite a bit closer yet. The existing holes are 15" from the rim I believe. Where did you drill the holes to pull the LNB back into where it wants to go?
Doug
