So I guess the WORLD movie channel is gone from voom, it's not Voom HD movies? I hope they still mix in the World movies, only place to find that many good international movies in HD.
Tony I have seen you post this a few times, but how do you explain the HD content that is actually on that channel? The sat and cable companies that do carry it arent just upconverting all of it. The "official" launch may be later, but TWC is putting out some HD content NOW
CHNG 9400 RSRCH MPEG4 SD Tp 32 EchoStar 3 61.5w UNAVAIL HIDE MAP 90
TO 9400 RSRCH MPEG4 SD Tp 32 EchoStar 3 61.5w AT100? HIDE
CHNG 9401 HITN MPEG4 SD Tp 32 EchoStar 3 61.5w UNAVAIL HIDE MAP 90
TO 9401 HITN MPEG4 SD Tp 32 EchoStar 3 61.5w AT100? HIDE
We have no obvious indication of any local(s) being removed overnight. What is your City?does anyone know why they took off our channel 6 it is a mass. local,it is the only one that went off overnight?
This one may have slipped by a few of you out there
Interesting stuff here. If I go to channels 9400 or 9401 on my 622 receiver and do a 6+1+1 (point Dish screen) the receiver will lock up. The picture will remain exactly as it was with a black screen in the "picture box" and all the other graphics intact. It will not respond to any button pushes on the receiver or remote. (you can hard reboot the receiver, BUT WAIT) Let it sit for about 10 minutes, the receiver will slowly come back to life. First you hear the signal tone. Then about a mnute later, the point dish screen shows up as it should, only 10 friggin minutes later!!!!
Anyway, it shows that on my receiver pointing at 110°, 119° and 61.5° channels 9400 and 9401 are being received from tp 32 at 61.5° and not 110° as it was yesterday.
Other than the point dish screen bug (which is a PITA) it seems to work just fine. PQ is about the same (I actually watch HITN some times).
See ya
Tony
I believe the 61.5 Providence SD locals moved transponder positions, to a TP that's a spotbeam and no longer ConUS, and to MPEG4 .. so most likely you may need a new receiver, milslim. It is my understanding that ABC 6, NBC 10, WPRI 12, CW 28 and FOX 64 migrated over. So if you only lost ABC 6, that's strange. :/
edit: vip211... nevermind... should work, no?
Tony, it was outlined a few times - don't wait too long while do SS check. SW would try to adapt to unusual condition ( tpn is in tables, but no signal ) and will try to 'compensate' nonexisting LOF drift, thus will tune to adjusted frequency from any input port of your switch.
Limited time offer
