dlp lamp | SatelliteGuys.US
dlp lamp
tanka
232
Toronto Canada
my frends not free to air but if you no just help .I change the lamp for my Panasonic dlp pt50dl54 tv and working good but the warning of changing the light is still coming on did one of you no to reset the tv I tray the volume and split buttons presse for five seconds but dont working.Tankyou
my frends never mine my problem solved if you have dlp pt 50dl54j dont buy the lamp from panasonic cust over 300 dolares canadian I did buy from usa shipping and lampe 130 usa working fine no problems to change the lamp then to reset presse the volume mines on the set and mute on the remote for 5 seconds
HBO on AppleTV
