DVR History? | SatelliteGuys.US
DVR History?
I don't even recall a DVR history page.... Obviously if there's no apparent "Delete" button, they must just fall off over time. I'll check to see what the oldest event we've got listed is.
Just checked mine... it goes back to 6/23. I have no idea how many events there were listed, but I assure, it's A LOT !! So, is the limit a total number of events or some time-limit ?? Given that mine lists ~35 days, which is an "odd" number, I'd guess it holds "x" of events. Oh yeah, no obvious way to delete them either.
Try a "Factory Defaults" (Menu - 6 - 6) if it's that important to you. I believe you'll have to enter all of your favorites, timers, etc. over again, but if you need to get something that's on that list out of there, it should do the trick.
any update on this issue? Does it only hold x number of events? Only save x number of days? Or a hidden way to delete em? Thanks.
510 and OTA from 811
How smart is the recorder when taping shows?
