Are all transponders on E14 7/8? I can see tp 11, 15 and 19 but not the rest.
I am on the western arc 110,119,129.
What at the national channels I might be receiving from the transponders that were switched to ECHOSTAR XIV?
On 6/10 a couple of CONUS TP's will move from 5/6 FEC to 7/8, the rest of them on 6/17. I suspect the few I have heard receiving a faint signal in Mexico will lose the lock on the signal with this FEC change.
Go to TheList or Dishchannelchart.com and click on 119. Click on the transponder header to sort by transponder. Now look for transponders 8,9,11,12,15,16,19,20.
Thanks digi. Got the answer, which is none.
I hope you mean "nothing I watch", because that process should list most of the channels that are most watched in the US, such as ESPN and CNN...
Read a few posts back.
Transponder 6,10,13,14,17,18,21 will move over to E14 on May24th AM. Spots will continue to move as referenced in the first post of this thread on 5/24, 5/26, 5/27.
Thanks Digi... any reason I'm only getting those 3 transponders and not the others off E14, since they all are 5/6?
Oh well, looks like my viewing from 119 is about done. I get 0 signal on all the conus feeds moved to echo 14. Good thing I pretty much only watch HD anyway.
If your wondering, Im at 114 by 64 (NWT, Can)
Wait until transition...you might need to repeak, remember they squeezed in 0.05 deg. a secon bird @ 118.?? and you are in fringe people in CONUS can't notice but in Fringe things are different.
The bird at 118.7 is on total different set of frequencies. So they didn't "squeeze" it in.
Not sure. What is your setup and location?
Sorry I meant no National HD channels. All national HD channels seem to be on Ciel2.
Limited time offer
