nayI am in the process of adding another 10 foot C-band to my farm. I have always used ribbon cable but unfortunately it is no longer manufactured.
I am going to use 12/2 sprinkler wire from Home Depot for the 36v actuator motor.
Here is where it gets complicated.
I am very happy with the performance of my Titanium LNBF however I am concerned that I might have to go back to a polarotor and filter with this 5G nonsense. For this I would need a cable for the polarity servo motor.
Obviously I need shielded cable for the actuator sensor and polarity servo motor. Can I use a 5 conductor shielded cable or do I need separate shielded cables for the actuator sensor and polarity servo motor?
Simply put, do the 2 actuator sensor wires need to be in their own shield isolated from the polarity servo motor wires?
I appreciate all help.
yes they should be in separate shields. One of the servo wires constantly sends pulses to the servo - you don't want that stuff interfering with your actuator sensor wires. Also, the shields should be grounded at the positioner end but not at the dish endI am in the process of adding another 10 foot C-band to my farm. I have always used ribbon cable but unfortunately it is no longer manufactured.
Hello I wouldn't suggest you use the 12/2 sprinkler wire from Home Depot for the 36v actuator motor because it is NON SHIELDED cable it will work, but down the road you will have problems.. what you need is some 18/2 shielded cable don't know how many feet you need but it comes in 100' and 500'I am in the process of adding another 10 foot C-band to my farm. I have always used ribbon cable but unfortunately it is no longer manufactured.
Limited time offer
