Stargazer said:That is the same situation that I have here. I know if I dont pick up the analog stations with an antenna then I definitely will not pick up the HD signal when it is being transmitted in low power.
DaveO said:Who woulda thunk?? So, don't arbitrarily count out getting digital channels just because you can't get the analog.
jcolombo said:Hmmm. It would make sense for D* to offer local HD in the major markets if they are going to compete with cable. Even though you can get HD via OTA, most people don't want to bother. Cable systems in the major TV markets are already offering the HD locals, so a "no antenna" solution is more attractive, and it probably makes TIVO functionality easier. More bandwidth required, obviously, but for major markets like NY, LA, Chi, etc. it would make sense.
John C.
Alan Gordon said:Of course, you might lose the Bingo channel, unless Rupe decides to pick it up!
~Alan
jcrash said:Doesn't DirecTV have an issue with thinking that it is OK to compress HD signals? I really would love my locals in HD via satellite, but if it means compression, well that isn't really HD now, is it? At best it means what you used to see you can now see in 16x9.
However, if they can find a way to get the major networks in Pure HD via satellite, I'll jump to DirecTV in an instant.
EdV said:To put the bandwidth issue into perspective, realize that each satellite carries only around 24 ku band transponders. A single transponder can carry only one HD channel using D*'s older qpsk modulation, or two using E*'s newer 8psk modulation.
If a typical local market has 4 channels, D* providing local HD to just 6 cities would consume the entire bandwidth of a single satellite. And they only have three satellites in the main 101-119 slots. So HD locals in the traditional sense is out of the question for the foreseeable future.
EdV said:However, there's still room for E* or D* to cut a deal for HD carriage in ABC and NBC owned and operated station areas and would require only one or two transponders. And that may in fact may be what D* is alluding to in the letter when they mentioned more local HD.
EdV said:I don't know about D*, but E*'s direction for local HD reception is OTA with an antenna. Last year they quietly offered the OTA module for free to any existing 6000 HD receiver owners. The new 811 and 921 receivers have the module integrated.
EdV said:And in the recent Chats, whenever Charlie mentions the integrated OTA capability, he always emphasizes that it will allow you to get your HD locals for FREE. Of course he carefully avoids the fact that many of you are in areas that cannot receive those signals.
Alan Gordon said:they could (not saying they will) carry 15,000 HDTV channels on the combined three satellites. ~Alan
SlicerMDM said:I think you have the wrong number of 0s ... I think it was 150,000 HD channels! No wait, 15,000,000! Yea, that's the ticket!
Actually, the real number was about 1500 HD channels. But who's counting. At any rate, it's a LOT of room for HDTV!!
ramcm7 said:Could D* "seamlessly" integrate local HD's into the service? Install HD OTA ant along with sat dish; integrate local HD's into program guide;
No, each Ku band DBS satellite carries 32 transponders. Depending on the encoding and other variables, you can get between 30-50Mbps usable out of one transponder. DirecTV is currently running mostly with two HD channels per transponder. Dish is also moving towards stat-muxing HD. As others have mentioned, the Spaceway satellites will likely be used for HD LIL. While the 1500 channels is a theoretical number simply based on total aggregate bandwidth capacity, it's moot anyway. Even if the number is only half that, it's still plenty to provide HD locals for most or even all of the major markets. There's only something like 1500 channels period. The number of those that are HD is quite a bit smaller.EdV said:...each satellite carries only around 24 ku band transponders. A single transponder can carry only one HD channel using D*'s older qpsk modulation, or two using E*'s newer 8psk modulation.
Limited time offer
