Firefox 22 | SatelliteGuys.US
Firefox 22
rodder
2,351
105
Adairsville,Ga 30103
I was wondering if anybody else was having problems with firefox22 with their bookmarks diapering from their bookmarks bar.Mine started diapering and i would add them back go out of fire fox and they would be gone again. I then deleted firefox and re installed it and it is still doing it i thing it is a problem with this 22 upgrade.:confused:
I'm not having that problem. Did you delete the profile when you uninstalled Firefox? You may want to save the Bookmarks, uninstall FF and delete the profile. Reinstall and import your Bookmarks.
Yep you got delete the profile or it won't help much.
Always make backups of your bookmarks as well.I try to back them up monthly.As often as FF updates these days,something is bound to break.
My bookmarks worked OK with 22, but I did have a problem with copy and paste between pages. Turns out it's a known problem with 22, so I went back to 21 and am waiting for 23.
Apple Developer Information may have been Compromised
