FOX new channel | SatelliteGuys.US
FOX new channel
pdqbobe
102
Has anyone had a problem with volume on this channel 412? I have to turn up the volume at lease 10 db to hear it well and sometimes I change channels and forget to turn down the volume which is very loud. Anyone is this a Voom or Fox problem? HD=Voom
Yep, I have noticed the same thing. I also have Directv and ESPN News volume is much lower than the other ESPN channels. I Haven't a clue as to why.
Thanks Ish1885 . I thought it was my reciever but I also tried D* on Fox this week end and the volume was lower also. It may be something to do with the broadcaster but I hope they fix this because when I channel surf I forget to turn the volume down to normal. Wife factor you know what I mean. HD=Voom
Comedy Central has much lower audio than any other channels out there. And this was true when I had D* as well. I say HAD because I am 100% VOOM now, cancelled my D*.
Voom has commented that they do nothing with audio volume levels - they only pass on what they get. If the other sat companies don't have this issue, then they are probably making adjustments - but the problem there is they will need to be prepared to move quickly if the source changes on them. By Voom not touching it, they virtually eliminate having to react to source audio changes...
problem with native setting
Don't let installer change times
