galaxy 15 at 133.0 w. | SatelliteGuys.US
chaskuchar
807
14
saint charles, missouri
i was looking for ewtn and could not find it on the list. had to go to lyngsat and finally found it. it moved off 17c at 91w. is there a special place to request getting galaxy 15, 133w on the list? thanks, charlie
yes, i was looking for it on my 6'. i know i can get it on my 8'. will have to work on it and see if i can adjust my dish perfectly. might try the microhd on this dish. i am using the azbox on the 6' and the microhd on the 8' if the microhd gets ewtn and the azbox doesn't i will put in for christmas for another microhd. charlie
How does someone make the scan that has information. How does it need to be formatted, I do not know how to make screen shots.
I can update TheList with a Channel Master file.
For one or two satellites I can manually update TheList with a microHD UDF channel file.
Thanks.
Thanks.
Thanks, I think. AS IN:
I take a clean receiver, blind scan the satellite, then export what I scan into Channel Master and send it to you? Yes?
However, I am thinking, reading 6 foot dish, this would be C band, which I do not yet have working. I, for one, am still near the bottom of the learning curve, So, I need to understand what language someone is speaking before I understand IF I can possibly help. As close as I am to 133, I will try to lean a dish against a wall and see what I can get. I am at 120, 133 is only 13 degrees off to the left and I can get 99 this way very well and that is 21 degrees to the right. So while watching grass grow I might --- oh wait, grass doesn't grow here.....
finally got to 133w with my 6' and azbox. scanned it in and got ewtn at 3807h16301. it is 60q and a solid signal. the microhd on the 8' has other ewtn at 3788h11935 but can't find it on 133w. charlie
over the air channels with a coolsat
FTA in Chattanooga
