Was that from China? I see a couple that ship from there and another retailer in the UK, which claims to be a distributor for TBS.Be carefull on Amazon, got a clone 6303 that would not switch polarity.
Make that a 6903.
Make that a 6903.
The seller used to be 'dvbforfun', but I see that some other company is selling in their place on Amazon.Be carefull on Amazon, got a clone 6303 that would not switch polarity.
Make that a 6903.
Hi,
I have been capturing the HRIT signal using goestools to decode and process it. I wanted to give the GRB signal a go and have found a 12ft Precision Parabolics E200 dish. I'm not sure of the specs as I can't find anything online, but looks like it might be a C Band one. Could someone confirm if this would work?
Hi Brett,
Thanks for all the great info. Did you ever make any headway with the streamer running on linux? I was thinking for my situation that I would put a small SBC (a RockPro64 as it has a PCIe 4x slot looks like the best candidate) close to the dish and power it with PoE so I can reduce any cable losses, and then have the big machine somewhere else in my network. I read in a later post that you removed the streaming functionality from GRB Imager, but just wondering if it can still receive a stream from udp?
I could only see the TBS6903X on amazon last night, so I think i'll go the eBay route or direct from tbs. I'm guessing dvbforfun on eBay is just TBS itself.
Did you install the TBS6903 device driver? You may download it at the following URL: TBS 6903 DriverHello,
Installed the TBS6903 card into a Win10 computer that has no other programs just GRB Streamer.
I get the message , after clicking the icon , " No DVB found. Unable to continue"..
Is there any other software needed to activate this card ?
Thanks for any and all help.
Darryl Zimmer
JPM sent. To initiate a "conversation" (PM) click on the user name in the Avatar and a box opens with options. One is for conversations.
Hello All,
Have GRB Streamer 2.11 operational..
Issues I had dealt with Digital Signature and W10. Defeated the Digital Signature an all is good now.
Also went to the TBS tuner web page and down loaded the W10 drivers.. Thanks Brett..
Looks like all that is left is the following : I have the coax installed on the bottom "F" connector , tuner 0..
I am seeing : Not Locked —— SNR = 1.42 to 2.30.. S=48. Q=0….
I see : "0" on sync error , circuit error and Frames Received..
Is the SNR a good number to have.. ?
What do I need to do to get : Frames Received, Start Streaming to function.
Thanks for any and all help, Darryl. Z.
1.42 to 2.30 is too low. You need at least 7 to lock the frequencies and receive GRB.Hello All,
They (Novra) got the GRB box working better. They fixed the problems I reported back in June.
Later I reported some bugs with Novra's GUI interface but have not heard back about any fixes for it.
The Novra box sent to the Department of Homeland security worked for a while and then could no maintain a signal lock. I think they went back to using a TBS DVB card on a Windows PC running my 'GRB Streamer' program while they are searching for a fix, possibly with the amplifiers.
I haven't been doing any further development of GRB Streamer (doesn't need it) or GRB Imager (could use it) because of injuries/illnesses I have had over the past 11 months. But I thought I would post here to help keep the thread from being closed due to lack of use.
Also, if anyone wants GRB Streamer or GRB Imager please let me know and I can direct you to the latest version (it's currently offered at no charge).
I have temporarily given up my attempts to get the TBS6903X to work well with GRB. Part of the problem is that my code to read and write to the STiD135 registers is flaky -- sometimes it works and sometimes it doesn't. I don't know why.
The best performance that I have gotten out of the TBS6903X is about 1 error per 400,000 baseband frames. That may sound good on paper, but compares poorly vs. the older TBS6903, which has an error rate of about 1 in 40 million.
Another problem is that my TBS6903X does not work after a cold start. It requires a cold start followed by a restart in order to work.
The older TBS6903s are still available on Amazon. So hopefully they will remain available for a very long time.
You can download GRB Streamer at: http://www.naturalgfx.com/GRBStreamer211.zipHows it going, I am working on getting a GRB station set up. What is the best way to get ahold of you for the GRB Software?
I think this is what you are looking for.Hey thanks for the reply, is this link broken? Can you paste the HTML link?
Hello Timothy,Hi again everyone,
Thanks Brett for continuing work of the hardware side of this. It's frustrating that there are several DVB-S2 Generic stream cards out there but only one works, and it's no longer being made anymore. Figures.
Brett, did you tell TBS that the chipset in that card is not as good or that much different then the old 6903 card?
Or they (TBS) really don't talk to you?
Limited time offer
