I'm glad to see weather01089 on here.
Weather01089 what Linux system are you running there with hardware details if you would detail please?
I know of no one that's using CSPP-GEO software other then Gov, or Universities.
I posted a while back the hardware needed to make such a required computer and it wasn't cheap. High end gaming computer.
I am most curious to know what it's running on as the sys. requirements are quite impressive.
2 dB C/N difference from there to here. Interesting.
Thanks for all your info and coming on here, welcome.
I think I'm going to try to get CSPP-GEO on Linux running here too.
CSPP-GEO is a very nice piece of software.
Again Thanks for the info.
I think with the addition of a Nooelec 'Sawbird LNA/Filter' and a Digital Devices card you would be able to receive GRB.
Mabie but I have one serious problem at the moment. I have no computer that has card slots for such.
I have been using a laptop for all the work so far as I take it to the dish to get the info.
One of my preferred requirements is that the receiver is to be a separate item of the computer. I had no plan of using the card version, but that could change.
I did find another card that's fair to the CC line card
that does have blind search, there a a couple of choices. Don't know how that they would work, but fully support generic stream.
PRO OMICOM S2 PCI V.# card
A cheaper one,
OMICOM S2 PCI
So hopefully you guys can help me out some.
I'm currently (attempting) using a 2.4m dish and I get between 6 to 6.5 C/N on my Ayecka (which unfortunately is not the GSE version of it). I do have a TBS5925 but don't see any indications it woulds support GSE (not that I've tested it).
Was thinking on upgrading the Ayecka to support GSE but from what I've been reading it appears the DD DVBS2 receiver might be better suited for it,
Welcome to the discussion.
Your right in the middle of us setting up such. So stay tuned to the forum.
That dish might work on the East COUNUS but I don't know. I do know that your at signal threshold there with a 6-6.5 C/N. That's what Brett is getting there in CA and it's touch and go.
The TBS5925 is the usb version of the cards that some of the guys have been using. I was kinda looking at the TBS5927. The 5925 will do the generic stream so I'd give it a try. As Brett said no has tried it yet so let us know.
Ayecka is wearing me thin as I had communication with them and after they wanted to know how many receivers I was going to buy (I told them 1) they seem not to want to talk to me anymore. From what I have been reading and getting from others and them as well they have been eliminated from my choices. They seem not to want to answer questions about their products, so I figure the support is just as equal. I don't spend that kind of $$ to be stuck with no support. I recommend you move on from them. Anybody else as well.
Weather 01089 said- I get up to 11 CN here in Western Massachusetts. Right now the dish is off aim and im testing the DD card with 6.8 and 7.6. Its doing really well. Ingesting both streams on the 2 ports
Excellent!
Indeed, has been running for a day. Data overload lol.
I don't know how you're keeping up with viewing all the products as it's just a lot. Ya, data overload is right.
You can watch your storage drive fill...
its inferior to the DD card.
So is their customer service.
Im using a septum feed, works great with a 10ft recycled tvro dish.
Same here with the 10' used dish, bought it for $25. Had to do some work on it but it's doing the job.
Well, the septum feed does work from what I'm reading here so I take back what I claimed earlier. But I'm going to stick with my combined 2 probe feed anyway. I only want to get the LHCP side anyway as the RHCP don't have much that I'm too interested in.
Brett, would there be any chance that the GRBStreamer code you made could be compiled on a Linux box?
Your thoughts...
