Not that they won't try to help, but it's a technical excuse freeing them from obligation.So I assume by that you mean the 1.5TB will work fine, but Dish won't help you if there's any problems?
There is a software limit to the size of the partitions created on the EHD.
I believe PSmith did the research.
from old posts:I knew he had, but I couldn't find the post and didn't know what software version his box was running when he last tried it.
You're right, Michael. Tested Seagate ST31500341AS disk with L621 - it's formatted OK and do shows ~1.4 GB free. I have a snapshot, but the site doesn't allow to upload it.
Nice, but L618 did not accepted 2 TB disk.
Tested same disk on 211, got error message #955 after successful formating.
I did check partitions, all of them are EXT3 type:
1 - 1 GB
2 - 500 GB
3 - 500 GB
4 ~400 GB (rest of space)
They're still allocating by 500 GB chunks and I see why 2 TB disk failed - you can't have more then 4 primary partitions as Dish FW use it with the limit of 500 GB per one partition.
So, the answer to OP question - 1.6 TB is the limit of EHD for 622/722 models.
Probably still not as good a deal as the Seagate FAD 1.5TB at Costco for the same dollars.Walmart.com: Western Digital WDBAAF0010HBK-NESN 1TB My Book Essential USB 2.0 External Hard Drive: Computers[/url]
This seems like a great deal and you can use a $15 off $75 coupon from Ebay to save more
From Slickdeals.net
Toshiba Portable External Hard Drives: 500GB $40, 640GB $60 - SlickDeals.net Forums
Toshiba portable HDD 640GB $59.99, 500GB $39.99 OfficeMax has portable drives Toshiba 500 and 640 GB fo the $39.99 and $59.99 respectively with FREE SHIPPING. May be price mistake, may be not.
http://www.officemax.com/catalog/...34421519-2
http://www.officemax.com/catalog/...33239286-2
100+How many HD recording hours can one expect on a 1TB drive?
Limited time offer
