Thanks, disconnecting the wireless seemed to work yesterday. Haven't checked it today. The DishNetwork subscribers that don't have access to Satellite-guys have to be going crazy with this release. "John"
For those having Joey connection problems, do your Joey's have connections to both Coax (MOCA) and ethernet?
I have similar problems when Joey's are connected to both, but not when I move the Joey to only one network. I think that S213 introduced a bridge loop or some other L2 problem in the network, which is resolved by physically limiting the number of paths. I chose to use ethernet only (at the Joey), so that I can still access home media. No problems with connectivity since.
Just remove one connection and then reset the entire network (Hoppers and Joeys).
We have a 1 Hopper, 3 Joey system in our house. We experienced the small window thing, but a rbr fixed that. Since then, the system is working flawlessly. So, it seems to me it's the multiple Hopper systems having trouble. As a side note, I had never attempted to connect to our network with any of the Joeys. They now work flawlessly with the internet connection of the Hopper. The Hopper is using a wireless connection.
I think you are right about the multiple hopper house holds experiencing the problems. I have one hopper and two joeys and KNOCK ON WOOD, haven't seen any of the issues discussed here. I did disconnect the joeys from the direct ethernet connections I had them plugged into. After doing that I reset the hopper network and they all show connected to the internet.
Ok I'm having to red button reset every morning . I think I have my set up right. I have 2 hoppers one is connect to my router the other hopper was connected by a USB
karspur said:I'm sure the answer is here somewhere but I can't find it. So sorry to ask, but...I have 2 Hoppers and 4 Joeys. I had both Hoppers connected with wireless adapters (router on opposite side of house from both) Do I need to keep both connected? After 213 update I tried to disconnect one and it didn't seem to work on that hopper or any of the Joeys. I have read so much about all of this that it just seems to confuse me more. Thanks to anyone that can tell me the best way to hook everything up right.
stimpson said:Is there an Ethernet connection any where close to one of the 4 Joeys?
Sent from my iPad using SatelliteGuys
I haven't tested myself, but I don't think the Joeys can act as bridges. You would probably need a HIC at the Joey location.About 6 feet or so. If I connect 1 Joey does that work for everything? Like I said, I'm just getting so confused.
sparc said:I haven't tested myself, but I don't think the Joeys can act as bridges. You'd need a HIC at the Joey location.
Limited time offer
