Nice!! took me a bit to find it, but it is right there as a option(Green Button) in the timers list.Yep! It's S234! Got it on one of the Hoppers. MANUAL TIMERS!!
also noticed that the PTAT folders tell you that "There are X unwatched recordings." now too.
S234: It appears that PTAT is always on, but only recording during primetime? Red button shows all big four networks are all active.
Favorite channels are disappearing again, or maybe they never stopped disappearing. And I still can't see the cursor when trying to save changes to the favorites list. I'm so sick of all these issues with such basic functionality.
Unacceptable.
The fav list button issue should have been fixed and it is on mine. Even if the buttons are not outlined, they still function. If you have your cursor set to invisible, then it may be difficult to see where you are on screen. You can change your cursor to anything but invisible and then you will have visual indication that the buttons are selectable.
Yeah, I can work around that, but the bigger issue is that my local channels disappear out of my favorites list and sometimes can't be added back in. I currently can't get ABC to stick in my favorites list.
I heard that the locals dropping issue is being investigated but for the time being I would try adding two channels to the list and see if that gets it to add. I believe that's the work around other members have been posting. I really don't use fav lists much but supposedly adding two channels will get them to save.
This has been happening to me since I upgraded to a Hopper. When I'm watching a recorded show, about 2 minutes before it ends, the show blips or hiccups for a half second, but keeps playing normal right after. It does this for all timer playbacks. Anyone else experience this?
Limited time offer
