I had the same idea she could've been in contact with some of scrappers and said take the dish. You had shown she was wrong so she was going to get you back. It would be low down if she would have done that.
So I got the the pole that fits the mount problem is my original 4OD pole opening is 3 3/8 not 3 1/2 like I thought so how should I go about getting this to fit?
I'm too new to say anything more. None of this passes the sniff test. Really? Somebody stole $3 worth of scrap and used a wetsaw to take it down? Been following this one with a bit of sympathy, but I call total Bullsh!t now.Inside job I am leaning towards not coltonjared.
They didn't use a wet saw to take it down. When I was referring to the wet saw I was taking about when I bought the pole and they had to cut it from 21ft to 8ft. No this was not a inside job cause if that was true first I'd be filing for divorce and also I wouldn't been able to get the second dish to put upI'm too new to say anything more. None of this passes the sniff test. Really? Somebody stole $3 worth of scrap and used a wetsaw to take it down? Been following this one with a bit of sympathy, but I call total Bullsh!t now.
Actually a Pinnacle is a very heavy dish and it's all aluminium. Probably $50 ~ $60 scrap. I have a couple of those and know what it's like to manhandle one onto a mount. I can understand why a scrapper would target that dish. My neighbor was a scrapper and used to remark about my dish being one of his favorites. Well my dish is still standing but he isn't .I'm too new to say anything more. None of this passes the sniff test. Really? Somebody stole $3 worth of scrap and used a wetsaw to take it down? Been following this one with a bit of sympathy, but I call total Bullsh!t now.
Don't remind me on how heavy the mount was damn near dropped it on myself trying to put it on the pole. I was surprised on how light the new mount is compared to the old one.Actually a Pinnacle is a very heavy dish and it's all aluminium. Probably $50 ~ $60 scrap. I have a couple of those and know what it's like to manhandle one onto a mount. I can understand why a scrapper would target that dish. My neighbor was a scrapper and used to remark about my dish being one of his favorites. Well my dish is still standing but he isn't .
An inexpensive option is to rig an alarm outside speaker/siren under the eaves with the trigger set to the normally closed option. Include 2 extra wires to the dish distribution wiring. If the distribution wires are cut, the alarm sounds. I have some 30watt/120dB horn types that wake the dead! Similar to these: www.ebay.com/itm/EXTRA-LOUD-ALARM-SIREN-HORN-SPEAKER-120db-All-Weather-Electric-Outdoor-Security/122786464254
Never had an AJAK myself but if it were me and one was available I would get it. I've seen many threads here of people adapting mounts to other dishes. Should be just a matter of obtaining/making brackets to connect the two properly.I was drive home from Illinois and seen a fiberglass dish but what caught my attention was that it has a ajak motor on it. How hard would it be to put a different dish in the mount? I already have a 10ft mesh dish behind my garage but the mount is severely rusted and I’ve been waiting on my mechanic to get around to fix it. Since I seen this I didn’t know if it would be worth the effort or not.
So finally I getting time to start this again. Got the new pole into the original one to put the mount on it just need to put a bolt threw it to hold it together but after beating it in with a
Sledge hammer I doubt it’s going anywhere. Also got it painted now need to figure out what color grey my dish used to be. Anyone of you guys know a color that closely matches it.
Limited time offer
