How do I know what type of LNB do I need to use? | SatelliteGuys.US
boypro
5
Sacramento, CA
Hi, I am newbie at FTA, and I am trying to learn it. Although I have read about LNB at other places, I am still confuse about the role of LNB, and how do I know how which one do I need.
For example, [ame="http://www.amazon.com/Dish-Network-1000-2-Satellites-Definition/dp/B000Q3WFFO/ref=sr_1_4?ie=UTF8&s=electronics&qid=1260545184&sr=1-4"]Amazon.com: Dish 1000.2: Electronics@@AMEPARAM@@http://ecx.images-amazon.com/images/I/21EI%2BmBoniL.@@AMEPARAM@@21EI%2BmBoniL[/ame]
This link will take you to amazon.com where they advertise the Dish-Network 1000 dish. By using it, I'll be able to pick up 110, 119, 129, but I am sure I need LNB for those, so which one do I need.
Thanks a lot for the advise.
For free to air, that dish you posted is pretty much useless. You need at least a 30" dish (preferably 36") and a KU Band LNB. The D1000 is too small and the LNB's are the wrong kind. You can get a few freebie channels off 119 like Nasa, Angel One & Ion but for most FTA you need the larger dish
The LNB takes the signals from the sky and downconverts them to frequencies we can use.
Check out our sponsers at the top for some good deals on FTA setups :)
Nimiq 5 on fta?
What have you done lately to deal with effects of the weather?
