Can you do it if you have (2) Hopper 3's bridged together in the same room?
When you do have (2) Hopper 3's Bridged together, can you see ALL the Recordings and Timers from BOTH H3's in the same LIsts and Folders, or are the kept separate?
With a Single Hopper 3, can you -
1. set a recording that you join In Progress (like a football game by example)
2. Then Pause that Recording,
3. Tune to another Channel and Watch TV,
4. and then Return to Original Recording which is still Paused where you left it?
Yes you can see all recordings but not timers. I have two H3's, one in the living room, the other in the family room both connected through the local LAN using the Ethernet ports on each.
Or, does that require another Hopper 3 or Joey in the same room?
What Dish receiver currently does that?
All Hoppers, PIP swap! When you PIP swap back the recording resumes play where you paused. If you tune a new channel instead of using PIP swap, it doesn't work. The PIP window is not necessary, that works, too. PIP swap on the 52 remote is the input button on the side.
(It works while recording is in progress. I have never tested resumption after the recording ends or the one hour buffer has expired.)
Only using PIP.So, are you saying with a Single Hopper 3, can you -
3. Then SWAP TUNERS and Tune to ANY Channel and Watch TV,
4. and then SWAP TUNERS back to the Original Recording which is still Paused where you left it?
Is that right?
Only using PIP.
I know what you are referring too.
The Genie has that feature.
You can swap 2 live tuners at anytime.
I Think it was called Double Play?
The H3 also has MultiView which allows you to watch and/or buffer 4 different things.
Can you give an example of how it buffers 4 different things?
Does it allow you to PAUSE 4 different things for up to an hour each and switch between them at will (like 4 different News or Sports Programs)?
Is that right?
Yes, using the input button, on the side of the 52 remote.
I used it all weekend watching football.
Not sure if it has to be recording or not. Now a 722 swap on a recording, it would not hold the paused location, I messed it up a few times watching racing.
I use to pause and swap my 722k all the time, this works as well.
I tested this with my VIP722K and it only works if you keep the Paused Tuner and the other Tuner in PIP Mode.
Once you go Full Screen with the "other" Tuner, the Paused Tuner is released from Pause.
Using the Hopper 3, can you Pause a Recording in Progress on the First Tuner, select a Second Tuner, go Full Screen on that Second Tuner and Watch TV, and then return to the Paused Recording on the First Tuner?
Sent from my iPad using the SatelliteGuys app!
I, and many others, have an 'off-air' tuner with our Hopper 3. What are you talking about ?Why no one talking about lack of off air tuner on H3.?
Limited time offer
