Why no one talking about lack of off air tuner on H3.?
If you mean the lack of availability of the Hopper OTA Adapter, its been reported that the new OT adapter will be available on Jan 24th.
Are you saying you can see all the Recording from both H3's on either/both H3's in one combined List/Folder as if they were all local to that machine (but not the Timers)?
Switch back and forth.
Not 100% sure what you're asking but an EHD will only show on the Hopper it's connected to.Do the RECORDINGS on EHD's connected to a Hopper 3 only appear separately in SOURCES?
Would it be the same for RECORDINGS to a EHD connected to a second Hopper 3?
Sent from my iPad using the SatelliteGuys app!
So your 2 Hopper 3s are on the same account?
The reason I'm asking is my Tech said I could have 2 Hopper 3s if I wanted as well.
But he didn't specify that I would need 2 Accounts.
Dish also said I can't have 2 accounts at the same physical address.
That can be rectified easily enough, But Dirt claims no way on the 2 Hopper 3s.
What can you do to clarify the situation?
Depends on who you ask. People here have (2) Hopper 3 units but the Dish reps here say it can't be done. When I had my H3 installed a couple of months ago, the technician was coming from a job .... with (2) Hopper 3 units.Is a Subscriber allowed to have (2) Hopper 3's under the current rules.
But the tuners on the 722k you can add new channels with out a full scan and no way to do that Hopper tuners.If you mean the lack of availability of the Hopper OTA Adapter, its been reported that the new OT adapter will be available on Jan 24th.
I have 2 hopper with sling receivers and dish anywhere allows you to select which hopper you are connected to. The only thing that I don't like is that you can't access any of the attached hard drives.
I also have a regular sling box attached to my living room hopper with sling and it allows you to do everything that you can do with a remote.
Limited time offer
