Sounds very likely that it's just a paramter change in the code. Hope so !![]()
A big Homer Simpson DOH!..... )
If someone has a hard drive set up can you run a test for me and see what results you get
Ever since I got the Manhattan I have tried to record the Montana football games (since it records HD fine normally and the azbox doesnt). When I try to play them back after a specific time (may be 10 seconds in, may be 2 minutes) the picture skips...as example I recorded a 5 minute segment and when I play it back at 1:45 it skips...it goes back to 1:43 and continually plays 1:43-1:45 then goes back. This is the only feed I've seen it on (all 3 or 4 weeks now). Sometimes it does it within 10 seconds of the beginning of the feed. If I FF past it a little bit later it will do it again.
Can someone verify it does it to them too?
More ammunition, I used Tsreader to RECORD the program, and then moved it to a usb stick. The Manhattan and Solomend 800 cannot play back this stream. They act the same way. I'm thinking some sort of copy protection, since there is a "private descriptor" in the stream, but I'm not smart enough to know.![]()
The signal doesn't have a high enough bit rate to seem to be a problem, but nonetheless , the recording doesn't play back on either Manhattan or Solomend 800, though Tsreader has no problem. Another of Iceberg's little mysteries.Mistake in data read
I had a chance to view, record and analyze the signal on Saturday. No copy protection on this SCPC signal.
0x86 is a Caption Service descriptor and is not related to the video issue.
Limited time offer
