What web browser are you using?i have downloaded it 5 times with the download button and it gives me a php file.
You crazy techie guy !i using firefox 7.01 with windows 7 this idm manager i am using will not let me down load from this site there is a key that i can set to let idm take over the download but is still not working.
Yup thats it, its that easy.Hi Guys,
I have been waiting for this firmware upgrade before updating my receiver. I chose to wait it out and did not upgrade to 3.2. This will be my first time updating the firmware on my Manhattan. Do I simply load the .ABS file onto a USB Stick, load it into the receiver and select the .ABS file from within the "Upgrade by USB" screen? Just want to make sure I don't mess up the receiver just when I get the software I was waiting for.
Many Thanks for your help.
and make sure the USB stick is FAT32 formatted. I didn't seem to have any luck with a NTFS formatted memory stick but did when I formatted that stick to FAT32.Hi Guys, Do I simply load the .ABS file onto a USB Stick, load it into the receiver and select the .ABS file from within the "Upgrade by USB" screen?
Wow, the help desk is busy today!
I am at 3.2, what steps would I take to save my channels, sats, and settings, load new FW, then bring those settings back in.
a couple of questions:
1) Does anyone know if the database format has remained the same for the last several months? I want to try my hand at the channel editor. When I was on version 3.2, I did a "user db" dump to the USB stick and upgraded to version 3.3. I downloaded the channel editor and I noticed the date in the editor filename seem quite a bit older than all the public firmware versions I'm aware of for the Manhattan and it is a concern to me that the database format may have been tweaked and that the channel editor's output db file may not be compatible with the Manhattan's version 3.3 firmware when I go to upload the "user db" to it.
2) Why is there an inconsistency with the info screens with the USB stick present and not present? Intentional? I did my version 3.3 upgrade, I saw a cool new lower third when I hit the INFO button. I hit the INFO button again and got some record screen. I figured that might be because my USB stick was still attached to the receiver and I safely disconnected the USB stick. The INFO button lower third then changed to a different version (not so cool appearance/info) and the second INFO button gave me the screen I had been lookign for all along (the S/Q and the new modulation type/FEC info). I don't know how to get to that S/Q/format/FEC screen when a USB stick is attached but I don't use my manhattan as a PVR _yet_ so it's not a showstopper to me to have to get to the more informative INFO screen without a USB drive present. I would have thought the INFO button screens would have looked similar no matter if there was a USB stick included or not and the record info woudl be found with the RECORD button keypress or through the menus.
3) Any plans to add video codec, audio codec, video resolution info in a future firmware to maybe the first lower-third INFO button keypress in a way similar to the openbox? That's the big thing of the openbox that I miss having in my manhattan.
Limited time offer
