Mercury II from Fortec Star | SatelliteGuys.US
clydecbd
2
I have a Mercury II from Fortec Star. When I powered it up a black box appeared on the screen and will not drop off. It almost totally covers the screen. Volume works but picture is blocked. Any help with this would be appreciated.
I remember seeing that on older receivers too. There should be a menu option to turn off the closed captioning
Whether you get it fixed or not, consider a more modern receiver that isn't so limited. You are losing out on over 1/2 of the programming you could receive.
re-calibrate a sg-2100 using usuals
Galaxy 19 (97W) Ku-band channel guide -- Feb. 25 update
