GEOSATpro - microHD updating | SatelliteGuys.US
GEOSATpro microHD updating
Save the udf before updating. Then reload the udf after doing a factory reset. That's how I just did it.
It is always recommended to perform a Master Reset and Power Cycle after a firmware update to avoid conflicts.
If the previous firmware maincode was 2013-11-14 (version 0.13) or newer, you should not need to perform a Master Reset after performing a firmware upgrade. This will retain your settings, satellites and channel lists. You would only need to set time and USALS Longitude/Latitude.
If previous firmware version was older than version 0.13, then the master reset is highly recommended and .udf User Database files should not be loaded.
GEOSATpro microHD Satellite Update Problem
GEOSATpro MP4 playback strangeness
