Moca symbal in lower right corner of screen | SatelliteGuys.US
If it's green then press YELLOW - BLUE - Whole-Home - Notifications
If it's not green then you have a MoCA line issue.
Sent from my iPhone 4S using SatelliteGuys
Mine is yellow. Says one of my Joeys is not connected to the network. How do I connect this one to the network?
Just found out this: I have two Hoppers and three Joey's - my three Joey's are all connected to one Hopper - no problem. I thought that they all needed to be connected to both Hoppers - they don't.
One of my Joey's was set to disable on the MoCA - causing the yellow on the bottom of my Hopper screen. I set it to enable and the yellow MoCA is now gone.
YEA!
YEA!
AND ....... IT'S BACK .....
Poor signal on EA 72
Switching from EA to WA
